Date/Time: Mon, 21 Apr 2025 17:31:57 +0000
[User Discussion] - Smoother DOM Re-center Setting
View Count: 335
[2023-02-10 21:02:10]
User417302 - Posts: 67
What interval setting would you suggest to make in order to have when the DOM re-centers? Currently, I have it set to adjust interval 3000ms (the default out of the box). It doesn't feel as smooth as it should be. Do you have a recommended setting for both fast (NQ, CL, RB, HO, etc.) and slower markets (ZB, ZS, ZW, ZC, NG, etc.)?
Thanks,
