Date/Time: Mon, 21 Apr 2025 18:10:42 +0000
Replaying various charts at the same time, one of them a TPO
View Count: 440
[2023-02-10 19:36:29] |
OriolCasas - Posts: 189 |
Hello, I am trying to replay all charts in chartbooks, some short timeframe full session charts and a TPO chart (I need them to work at the same time) I've read on the website that all charts need to have the same session times to work properly. My issue is, how can I make TPO market profile charts work on a full session chart time session? I've tried a setting inside the market profile study but until now I didn't find how to do such thing. Can you help me? Thank you |
[2023-02-10 22:48:06] |
John - SC Support - Posts: 39380 |
To have the TPO profile use the full Session, you just need to make sure the Session Times are set properly - which would mean setting the option for Use Evening Session to Yes if you have separate Evening Session hours defined.
[2023-02-10 22:56:09] |
Sorry I think I didnt explain myself good enough I want my TPO charts to work with the setting: use evening session - yes But TPOs to show only RTH hours So I can replay the charts together with all my other charts |
[2023-02-13 22:32:29] |
Sierra_Chart Engineering - Posts: 19289 |
Duplicate that chart: Using Chart Templates: Duplicating Charts / Template Charts And then remove the TPO Profile Chart Study from the duplicated chart. Do you see the full 24 hours of trading in the chart? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
