Date/Time: Mon, 21 Apr 2025 17:37:49 +0000
ø
View Count: 340
[2023-02-10 16:42:49]
sgne - Posts: 109
ø
Date Time Of Last Edit: 2024-12-05 04:14:52
[2023-02-10 18:44:07]
John - SC Support - Posts: 39380
The Spreadsheet will only be saved if you save the Chartbook. This also applies to the option for Auto-Saving the Chartbook. So one option is to turn off the Auto-Save Chartbook option. Refer to the following:
General Settings Window: Auto-Save Chartbooks (Global Settings >> General Settings >> Charts >> Chartbooks)
[2023-02-10 20:22:54]
Sawtooth - Posts: 4209
I can confirm that the spreadsheet is saved even if you click No when asked to 'Save Any Changes...? when closing a chartbook.
Even with Auto-Save Chartbooks set to No.
[2023-02-11 00:01:08]
Sierra_Chart Engineering - Posts: 19289
There are Backups of spreadsheets made. Go to the /Backups subfolder in the Sierra Chart installation folder. You will have prior copies of your spreadsheet there.
[2023-02-13 22:33:33]
At this point we are not sure, where the spreadsheet is being saved, other than when saving a Chartbook or the spreadsheet. We did look into this but could not identify any other place.
[2023-02-14 00:32:22]
If you close a chartbook, and choose not to save it, the CHT is not saved, but the SCSS is saved.
This shouldn't happen.
[2023-02-14 02:13:11]
We identified the issue. This will be resolved in the next release.
