Date/Time: Sun, 12 May 2024 00:13:14 +0000
Unable to Achieve Connection
View Count: 1733
[2013-05-01 13:54:22] |
Scott Perry - Posts: 17 |
I have been a Sierra user for 4 years and I feel as though I know my way around the platform extremely well. However, I signed up for a TST Combine and I'm using Sierra for enter/exit of trades. I had a practice account with TST that lasted 2 weeks and I was able to get connected just fine. However, since the practice account expired I can't get a connection, which is understandable. However, I signed up for a TST Combine and I can't get a connection. I have everything input properly and I have contacted TST Support and they say they can connect to my account through their Sierra platform. So evidently there is something not working properly on my end. Attached is a Screenshot of the Activity Log after I try to connect. Would it be possible for you guys to remotely connect to my computer and see what might be up? Thanks, Scott Perry 501-352-7740 |
untitled.JPG / V - Attached On 2013-05-01 13:54:18 UTC - Size: 122.02 KB - 596 views |
[2013-05-01 14:21:37] |
I've got something really wrong... my charts will not show any data past 4/27/2013. I can connect to the SC Historical Data and get a green connection, but still the charts stop at 4/27/2013. Is there anyway someone from your end can remotely look at my computer and let me know what is happening... please? Thank you, Scott Perry 501-352-7740 |
[2013-05-01 14:25:32] |
It appears as though you are running the non-CLR version which currently does not work with CTS T4. Update Sierra Chart by selecting Help >> Download Prerelease. If you still need help, post a copy of the Message Log, by following these steps: https://www.sierrachart.com/index.php?l=PostingInformation.php#log About the Sierra Chart Historical Data service and your charts not updating, most likely you are using symbols which are not supported by that service. Open new charts using the correct symbols by selecting File >> Find Symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-05-01 14:27:31
[2013-05-01 14:29:34] |
Ok thanks... I'm doing this now... BTW my current version is 969 if that means anything... I updated this morning thinking that would help.
[2013-05-01 14:31:23] |
Seems to have done the trick. Thanks!
