Date/Time: Tue, 26 Nov 2024 19:42:56 +0000
mistake message?
View Count: 963
[2014-06-10 08:37:36] |
User30743 - Posts: 365 |
hi, anytime i open sierra chart, there is a message telling me something i dont understand. when i click YES it takes very long time to load, when i click NO it is ok. the point is i dont know what the message is saying.. viz screen
m.dib - Attached On 2014-06-10 08:37:34 UTC - Size: 101.51 KB - 409 views |
[2014-06-10 08:41:18] |
This message is about reducing the size of Intraday chart data files. More information can be found in this section here: http://www.sierrachart.com/index.php?l=doc/doc_DataSourceSettings.html#LargeDataFileSettings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
