Date/Time: Mon, 21 Apr 2025 17:29:53 +0000
Teton size limit
View Count: 487
[2023-02-10 09:42:26] |
User801402 - Posts: 21 |
Hi Sierra Team, is it possible to have a limit for maximum position = 2 contracts and still be able to use brackets? I mean a setting in Teton, not on the sierra chart frontend. What would be the setting that the broker has to set in Teton? The point is, that i would need more orders in the market than allowed quantity. Does this work without negative issues? Thank you very much |
[2023-02-10 15:51:26] |
Sierra_Chart Engineering - Posts: 19289 |
Yes you can: is it possible to have a limit for maximum position = 2 contracts and still be able to use brackets? This works without any issue. The position limit can be set to whatever you want your maximum position to be, and you will not have problems with Attached Orders.
[2023-02-10 16:44:26] |
OK, but what are the correct settings for the broker to set in Teton? Max position = 2 and max size = 2 ? Or anything else? THX |
[2023-02-10 19:05:27] |
Yes the maximum position quantity = 2 and the maximum order quantity = 2.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-02-10 19:05:44
