Date/Time: Mon, 21 Apr 2025 17:40:45 +0000
Right click
View Count: 356
[2023-02-10 05:14:47] |
Baxterkd - Posts: 2 |
I’m unable to right click on a MacBook Pro to merge volume profile on a TPO chart. This potentially could be from having an older MacBook however I thought it may be that I only have the level 5 advanced Subscription. Any thoughts would be greatly appreciated. Thank you
[2023-02-10 16:41:17] |
John - SC Support - Posts: 39380 |
It is not related to your package. Either you have access to the TPOs or you do not. If you do not see anything when you right click, then this is going to be related to the MAC and the tools you are using to run the Sierra Chart software on a MAC. This is not something we have any insight into, so it's not something we can help with. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
