Date/Time: Mon, 21 Apr 2025 17:40:45 +0000
See the volume profile as you move the drawing box area
View Count: 499
[2023-02-09 23:53:10]
dberliner - Posts: 16
Currently when I'm drawing a volume profile I can only see it in a static way, that is - once I clicked the mouse and put the box in place.
I've seen videos of Sierra users where the profile is shown while the box is still being drawn, so you can dynamically move the box area and the profile would change before setting it in place.
Wondering as to how to enable this.
Thank you!
DB
[2023-02-10 16:05:04]
John - SC Support - Posts: 39380
You can not do it when you are first drawing the profile. But if you edit the profile and as you drag an edge, the profile will update.
