Date/Time: Mon, 15 Dec 2025 09:10:56 +0000
How to show total orders?
View Count: 637
| [2023-02-09 22:05:20] |
| projec3t - Posts: 2 |
Hi, I was just wondering how to make it so my chart looks like the screenshot (specifically how i get the yellow text). Just want to tighten the range to save time instead of scrolling up and down as my total orders is quite far down. Thanks Date Time Of Last Edit: 2023-02-09 22:11:21
| [2023-02-09 22:53:18] |
| John - SC Support - Posts: 43443 |
You need to start with two copies of the Bid and Ask Depth Bars with the Calculation Mode for one set to Sum Bid Side and the other set to Sum Ask Side. The Close Subgraph will then have the sum of the Market Depth. Refer to the following: Bid & Ask Depth Bars In terms of displaying the information, the easiest way would be to use two copies of the Text Display for Study (one for the Bid and the other for the Ask). Refer to the following: Text Display For Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2023-02-10 08:04:56] |
| User877753 - Posts: 152 |
Hi, for the yellow text : seems that Chart DOM Settings/Other/Display DOM Depth Totals give the sum of Bid and Ask too, for all charts/DOM. It's a global setting. Regards JM |
