Date/Time: Mon, 21 Apr 2025 13:05:47 +0000
Save all chart data to a stick drive
View Count: 353
[2023-02-09 18:24:40] |
User986474 - Posts: 35 |
How do I save my chartbooks to a stick drive or any other backup device?
[2023-02-09 18:40:01] |
John - SC Support - Posts: 39362 |
Exit from Sierra Chart and copy the files to wherever you want to back them up to. Refer to the information at step #5 of the following link for the various files and what they contain and where they are located: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
