Date/Time: Mon, 25 Nov 2024 01:44:23 +0000
Maximum Show Quantity how to use this?
View Count: 419
[2023-02-09 15:57:23] |
User193762 - Posts: 13 |
20230208_231250.png / V - Attached On 2023-02-09 15:57:06 UTC - Size: 68.39 KB - 105 views |
[2023-02-09 23:32:47] |
Sierra_Chart Engineering - Posts: 17166 |
You just simply enter a nonzero, positive, number there but we really really do not recommend using it. You are going to run into problems with it.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-02-09 23:33:03
[2024-04-15 15:23:30] |
TonyCipriani - Posts: 18 |
Hello, Is it possible if you can clarify what issues one may run into by using the Maximum Show Quantity feature? Thanks a lot |
[2024-04-16 03:35:21] |
No, the quantity is passed through to the exchange. The exchange is only able to properly explain the limitations. We have just heard about too many issues associated with it.
