Date/Time: Mon, 21 Apr 2025 13:05:46 +0000
Denali Sierra Data + Rithmic Trading
View Count: 642
[2023-02-09 15:09:06] |
User931218 - Posts: 2 |
Hi there, is it possible for me to use the Denali Data feed that I pay for with Sierra Chart but use my Apex Rithmic Account to trade? Currently I am taking these trades through seperate software but I would rather use Sierra to trade. Thanks |
[2023-02-09 16:00:25] |
John - SC Support - Posts: 39362 |
Yes, you can do this. Refer to the following: Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services It sounds like you will be connecting to multiple trading accounts. If this is correct, then we recommend using multiple installations of Sierra Chart. Refer to the instructions here: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
