Date/Time: Mon, 25 Nov 2024 12:42:33 +0000
eurex issues?
View Count: 447
[2023-02-09 09:05:47] |
Bango - Posts: 76 |
This morning Eurex seems to have problems. Have you seen something by your side?
[2023-02-09 10:00:12] |
Bango - Posts: 76 |
No problem with Denali... I think it's a CQG issue (I had 5 disconnections) here's the first: CQG WebSocket socket (1) | Close event error. Windows error code 10053: Connessione interrotta dal software del computer host. | 2023-02-09 08:01:19.769 * CQG WebSocket socket (1) | Socket gracefully closed by remote side. | 2023-02-09 08:01:19.769 CQG WebSocket socket (1) | CloseSocket call. | 2023-02-09 08:01:19.777 CQG WebSocket socket (1) | Max send buffers used during socket life: 5 | 2023-02-09 08:01:19.777 CQG WebSocket socket (1) | Max send buffer size during socket life: 309 | 2023-02-09 08:01:19.777 CQG WebSocket | Network socket for WebSocket has been closed by remote side or error. | 2023-02-09 08:01:19.777 CQG WebAPI | WebSocket closed. | 2023-02-09 08:01:19.777 Connection to the external service has been lost. | 2023-02-09 08:01:19.777 CQG WebSocket socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-02-09 08:01:19.777 CQG WebSocket socket (1) | Closed. | 2023-02-09 08:01:19.777 CQG WebSocket socket (0) | CloseSocket call. | 2023-02-09 08:01:19.800 CQG WebAPI | Disconnected. | 2023-02-09 08:01:19.801 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-09 08:01:19.801 CQG WebAPI | Connecting to server api.cqg.com | 2023-02-09 08:01:21.942 CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2023-02-09 08:01:21.942 CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2023-02-09 08:01:21.957 CQG WebSocket socket (1) | New receive buffer size: 5242880 | 2023-02-09 08:01:21.957 CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2023-02-09 08:01:21.957 Denali Data Feed | Heartbeat from server | ServerReceivedClientHeartbeatSecondsAgo=12, NumberOfOutstandingSendBuffers=1, TransmissionDelayInMilliseconds=150, ServerSendBufferSizeInBytes=41, ActualMessageDelay=0.1 seconds, DataCompRatio=2.13, UncompressedBytes=1772354, CompressionTime=0.018830(secs), NumCompressions=1567, Source=176.9.9.252 | 2023-02-09 08:01:30.090 Denali Data Feed | Heartbeat from server | ServerReceivedClientHeartbeatSecondsAgo=17, NumberOfOutstandingSendBuffers=1, TransmissionDelayInMilliseconds=150, ServerSendBufferSizeInBytes=663, ActualMessageDelay=-0.0 seconds, DataCompRatio=2.02, UncompressedBytes=3509634, CompressionTime=0.018788(secs), NumCompressions=2173, Source=10.10.20.73 | 2023-02-09 08:01:33.251 CQG WebSocket socket (1) | Connect event error. Windows error code 10060: Impossibile stabilire la connessione. Risposta non corretta della parte connessa dopo l'intervallo di tempo oppure mancata risposta dall'host collegato. | 2023-02-09 08:01:42.986 * CQG WebSocket socket (1) | CloseSocket call. | 2023-02-09 08:01:42.986 CQG WebSocket | WebSocket closed. | 2023-02-09 08:01:42.986 CQG WebAPI | WebSocket closed. | 2023-02-09 08:01:42.986 CQG WebSocket socket (1) | Closed. | 2023-02-09 08:01:42.986 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-09 08:01:42.986 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-09 08:01:42.986 CQG WebSocket socket (0) | CloseSocket call. | 2023-02-09 08:01:43.002 CQG WebAPI | Disconnected. | 2023-02-09 08:01:43.002 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-09 08:01:43.002 CQG WebAPI | Connecting to server api.cqg.com | 2023-02-09 08:01:45.098 CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2023-02-09 08:01:45.098 CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2023-02-09 08:01:45.098 CQG WebSocket socket (1) | New receive buffer size: 5242880 | 2023-02-09 08:01:45.098 CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2023-02-09 08:01:45.099 Denali Data Feed | Heartbeat from server | ServerReceivedClientHeartbeatSecondsAgo=12, NumberOfOutstandingSendBuffers=1, TransmissionDelayInMilliseconds=150, ServerSendBufferSizeInBytes=1303, ActualMessageDelay=0.1 seconds, DataCompRatio=2.14, UncompressedBytes=1944667, CompressionTime=0.020193(secs), NumCompressions=1671, Source=176.9.9.252 | 2023-02-09 08:01:50.046 Denali Data Feed | Heartbeat from server | ServerReceivedClientHeartbeatSecondsAgo=17, NumberOfOutstandingSendBuffers=1, TransmissionDelayInMilliseconds=150, ServerSendBufferSizeInBytes=128, ActualMessageDelay=-0.0 seconds, DataCompRatio=2.02, UncompressedBytes=3780842, CompressionTime=0.019975(secs), NumCompressions=2287, Source=10.10.20.73 | 2023-02-09 08:01:53.283 CQG WebSocket | Opening WebSocket. | 2023-02-09 08:01:54.142 CQG WebSocket | Sending WebSocket handshake. | 2023-02-09 08:01:54.142 CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols | 2023-02-09 08:01:54.259 CQG WebSocket | Server header | Connection: upgrade | 2023-02-09 08:01:54.259 CQG WebSocket | Server header | Sec-WebSocket-Accept: ea002q/AiWf5cWIEQ6WCpdA1KUg= | 2023-02-09 08:01:54.259 CQG WebSocket | Server header | Server: WebSocket++/0.7.0 | 2023-02-09 08:01:54.259 CQG WebSocket | Server header | Upgrade: websocket | 2023-02-09 08:01:54.259 CQG WebSocket | Server header | | 2023-02-09 08:01:54.259 CQG WebSocket | Web socket state is now open. | 2023-02-09 08:01:54.259 CQG WebAPI | WebSocket connected. | 2023-02-09 08:01:54.259 CQG WebAPI | Sending market data logon message. | 2023-02-09 08:01:54.259 CQG WebAPI | Base Time: 2023-02-05T08:56:19. 2023-02-05 08:56:19 | 2023-02-09 08:01:54.620 CQG WebAPI | Logon successful. Session Token = V8kUx7/7jvew1hp/YNwbb4FH7OmvbS9aV7SlQ04RVkcIy7gqbUXID0nw/ZxEDafrdEidJtYW7C1 | 2023-02-09 08:01:54.620 CQG WebAPI | Connected to server complete. | 2023-02-09 08:01:54.620 Date Time Of Last Edit: 2023-02-09 10:03:19
[2023-02-09 10:02:02] |
Bango - Posts: 76 |
Any suggestion to a reliable Eurex order routing? Perhaps TT?
[2023-02-09 10:53:06] |
Sierra_Chart Engineering - Posts: 17172 |
We will check.
[2023-02-09 10:55:11] |
The EUREX data feed is fine. So it is a connection problem with CQG in your case. To access the EUREX data independently follow the instructions below. To access historical and streaming market data independent from your Trading service. Follow these instructions. Set "Global Settings >> Data/Trade Service Settings >> Current Selected Service" to "SC Data-All Services". Press "OK" And then translate the symbols in your Chartbooks and Sierra Chart using this "Edit' menu command: Edit Menu: Edit >> Translate Symbols To Current Service (Translate Symbols to Current Service) You can then use the data provided by Sierra Chart independent of your trading service. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-02-09 10:55:26
[2023-02-09 11:09:59] |
Bango - Posts: 76 |
This way I can't place order on CQG account though. SC goes in SIM mode as I place live orders. Am I missing something?
Date Time Of Last Edit: 2023-02-09 11:11:50
[2023-02-09 11:57:23] |
What you can do is have one installation just for accessing EUREX data. And another installation for CQG for trading. If the instance set to use CQG has an issue, at least you can still watch the charts. Refer to: Using Multiple Data and Trading Services at the Same Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-03-01 04:42:07] |
Jimmyy - Posts: 221 |
Bango, Which tickers do you trade in EUREX ?
[2024-03-01 09:59:24] |
Bango - Posts: 76 |
Hi Karohm, not trading Eurex anymore
