Date/Time: Mon, 21 Apr 2025 13:05:51 +0000
data
View Count: 343
[2023-02-09 00:28:24] |
User221162 - Posts: 1 |
not getting any data when all cqg data settings seem to be correct. getting error message "historical data only supported with sierra chart data feed" not sure how to get this data |
[2023-02-09 13:35:35] |
Sierra_Chart Engineering - Posts: 19285 |
Complete the market data agreements here and activate the exchanges that you need: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation#DenaliCME Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-02-09 15:44:00] |
SC Support - Posts: 1954 |
Hi User221162, I can give you a quick call to help with this set-up if you wish? Please let me know.
Date Time Of Last Edit: 2023-02-09 15:44:11
