Date/Time: Tue, 26 Nov 2024 19:55:12 +0000
Random Candle Start
View Count: 991
[2014-06-09 19:54:18]
GCAdmin - Posts: 35
Could you please explain why for the past two weekends, I am getting a candle that is starting even though my chart settings are set to NOT load weekend data? I have attached a screenshot. It is causing concern to some that their studies are not showing correct indications because it compensating for this random candle.Is there a reason that it is showing up? How could I get rid of it? It is showing up on all Intraday Daily chart pairs. It just appeared last weekend so I figured I would see what it did this weekend and it did it again. Please help.
Private File
[2014-06-09 22:44:12]
We have discovered why this is happening. We are going to be implementing a solution to this, this evening for it.
Tomorrow morning you will need to re-download the data from before those empty bars by right clicking on the chart before those bars and selecting Delete and Download Data.
[2014-06-10 17:32:08]
GCAdmin - Posts: 35
Thank you.
[2014-06-11 01:37:15]
We have not completely solved the problem yet. This will be done by morning.
