Date/Time: Mon, 21 Apr 2025 13:05:40 +0000
does Chart Replay support newly designed Attached Orders?
View Count: 350
[2023-02-08 19:11:00]
jsob - Posts: 39
I would like to test the performance of a newly designed Attached Order while running a chart replay. Can I do this?
[2023-02-08 23:19:48]
John - SC Support - Posts: 39362
If you run the Replay at a low speed (1 or 2) then you will be able to see how this functions. But if you want to run it over a longer range of values, then you would need to use the Back-Testing option. Refer to the following:
Auto Trade System Back Testing
[2023-02-09 13:41:31]
Sierra_Chart Engineering - Posts: 19285
Yes and here is the documentation for replay:
Replaying Charts: Basic Chart Replay Instructions
Submit the orders as you normally do when a chart is replaying.
