Date/Time: Mon, 21 Apr 2025 13:11:36 +0000
2nd comp feed setup
View Count: 354
[2023-02-08 16:44:43]
User882361 - Posts: 5
I did read through loads of things beforehand but I fund no joy to my question... ( probably I missed it somewhere.. ) so the Q is : I have my Denali feed from U guys Sierra = good or rather would say excellent. My AMP acc live is connected = working fine I see live quotes coming through = perfect. So after bitching and moaning here a lot ;))) if I want to have the second comp to run Sierra ( I know I can have it, and I do understand clearly I need to pay for the '2nd' set of Denali feeds = fine ) but do I need to ask AMP for a 2nd setup, or I just sort out the 2nd set of Denali Feeds payed from my Sierra acc. , and on the other comp I would be able to login and run Sierra with the same AMP given CQG creds and with the same Sierra acc of mine cerds? >>> if so yes, then how/where do I choose to pay for the 2nd set of Denali feeds?
[2023-02-08 16:52:50]
John - SC Support - Posts: 39362
Follow the instructions at the following link to add the second set of Exchange Fees to allow a second computer to access those exchanges from 2 computers at the same time:
Denali Exchange Data Feed: Denali Exchange Data Feed on Two Computers Simultaneously
Just note that CQG may not allow for multiple connections at the same time. So even though you will have Sierra Chart setup and working on two computers at the same time, you may not be able to submit orders from both systems at the same time. You will need to check with AMP on this.
[2023-02-08 17:30:19]
thanks John... I am not gay, but I feel like I owe U a blowjob... ;))) >>> yup I'll check it then first with AMP = thank you for your HELP !!!
Date Time Of Last Edit: 2023-02-08 17:30:46
