Date/Time: Tue, 26 Nov 2024 18:28:39 +0000
Cumulative Delta Bars - up / down tick (Trades)
View Count: 1344
[2014-06-09 19:07:25] |
User78745 - Posts: 38 |
Dear all, Someone knows if there is a study which represents CD bars up/down tick (Trades & not Volume). Thank you for your prompt reply. regards, |
[2014-06-09 19:29:14] |
Use the Cumulative Delta Bars-Ticks study: http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s296 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-06-09 19:29:27
[2014-06-09 19:39:35] |
Tx, Regards, |
