Date/Time: Tue, 22 Apr 2025 02:18:45 +0000
Highlight the end of signle print on TPO chart
View Count: 837
[2023-02-08 09:53:08] |
Amarreddy - Posts: 7 |
Hi, I have seen there is only one option to highlight the begining of the single print on TPO chart. Is there any option to highlight the end of single print?. Please let me know |
[2023-02-08 16:08:04] |
If you set the TPO's to be "Letters/Blocks in Own Column" and you set the Extend Singles to Until Future Intersection, then you will see the line drawn from where the single starts to where it "ends". If you are looking for something else, then that would not be available. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-02-08 16:31:45] |
Hi John, The setting you mentioned only highlights the point of start of single print. But it doesn’t highlight where it ends “vertically “. I hope the necessity of future taken seriously to be implemented in Sierra chart. Thanks |
[2023-02-26 19:09:43] |
whats1thingnow - Posts: 407 |
please reference, upvote and comment on this thread from 2017 instead for the same feature request: TPO Single Prints
