Date/Time: Mon, 21 Apr 2025 13:05:43 +0000
symbol entry on second instance not working
View Count: 308
[2023-02-08 05:19:08] |
$tack - Posts: 100 |
I started a second instance of SC and have it setup to use DTN IQ Data feed. The issue I'm noticing is that when I try to enter a symbol in a chart, I press "/" and enter a symbol and press enter but nothing happens. Instead I need to use the Find Symbol feature and then switch chart symbol to get it to work. When I just have one SC instance the "/" symbol entry method works just fine. Is this a bug? |
[2023-02-08 15:45:57] |
John - SC Support - Posts: 39362 |
In the instance for which the functionality is not working, check to ensure that the setting for Global Settings >> General Settings >> Chart >> Support Symbol Entry from Chart Window is set to Yes.
