Date/Time: Mon, 21 Apr 2025 13:11:37 +0000
Need a alternative for =XOR
View Count: 583
[2023-02-08 05:18:39]
User29194 - Posts: 5
"=IF(XOR(AO3=1,AS3=1,AW3=1,BA3=1),1,0)" Returns "#NAME"
What alternatives are available to get the same results as above?
"=IF(OR(AND(AO3=1,AS3=1,AW3=1,BA=1),AND(AO3=-1,AS3=-1,AW3=-1,BA=-1)),0,1)" works in excel but not in sierra charts.
Date Time Of Last Edit: 2023-02-08 13:03:04
[2023-02-08 15:43:35]
John - SC Support - Posts: 39362
If you copied and pasted the second equation, then the issue is that you are missing the row reference for the BA column.
See if the following works:
=IF(OR(AND(AO3=1,AS3=1,AW3=1,BA3=1),AND(AO3=-1,AS3=-1,AW3=-1,BA3=-1)),0,1)
[2023-02-08 16:49:15]
Sawtooth - Posts: 4209
This in excel...:
=XOR(AO3=1,AS3=1,AW3=1,BA3=1)
...is this in Sierra Chart spreadsheet studies:
=OR(AND(AO3=1,AS3=1,AW3=1),AND(AO3=1,AS3=1,BA3=1),AND(AO3=1,AW3=1,BA3=1),AND(AS3=1,AW3=1,BA3=1),AO3=1,AS3=1,AW3=1,BA3=1)
See attached pic.
imageXOR function.PNG / V - Attached On 2023-02-08 16:48:51 UTC - Size: 108.69 KB - 114 views
