Date/Time: Mon, 21 Apr 2025 13:14:33 +0000
Newbie Cannot Find Setting for Volume Per Bar
View Count: 330
[2023-02-07 21:24:47] |
User309241 - Posts: 2 |
I am new to SC and are following instructions on an older video to set up a 3000 Volume Per Bar Chart but the software has changed and the Chart window for doing this does not exist. Could some one please help me with that and setting up session time.
[2023-02-07 21:51:17] |
Le Dharma - Posts: 82 |
I am just a regular user of sierra, but perhaps I can help. Right click the chart, select chart settings, and a black window will appear. 3rd option in will say, Bar Period - select that. Under Intraday Chart Bar Period - Select Bar Period Type. Second option down will say, ''Volume per Bar'. Then Set the amount of contracts you wish for (3000), in the below option - 'Bar period value'. I hope this helps. GL man. |
[2023-02-07 23:40:10] |
John - SC Support - Posts: 39362 |
The documentation for this is the following: General Settings Window: Additional Days to Add to Rollover Date for Chart and Quote Board Rollovers (Global Settings >> General Settings >> Charts >> Charts) Note that in the documentation the title for the section gives you the path to the specific setting ( For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
