Date/Time: Mon, 21 Apr 2025 13:11:39 +0000
Daily Chart Data not displaying
View Count: 306
[2023-02-07 21:21:14] |
Le Dharma - Posts: 82 |
Hey Sierra. I am looking into trading Softs (ICE data from CQG), and I do not see the current day displayed on my daily chart. On my intraday Chart, I can see 2-7-23 correctly, but on the daily chart, there is no bar for today, the 7th. Also, it would appear that the volume roll-over point for the ice data, is simply yesterday, and not actually based on volume. And to make matters even worse, I can only see the past 5 days of BV and AV, for some of the ice contracts. Is this how far SC and ICE have drifted? Or is there something that can be done here? |
[2023-02-07 23:37:54] |
John - SC Support - Posts: 39362 |
As you note, you are getting the ICE data from CQG. Any issues you are having are related to the CQG data, except the rollover. If you are getting a notice about a rollover for ICE, then you would need to check the Symbol settings for the particular product and see how they are set. Refer to the following: Global Symbol Settings: Instructions Also, you can adjust the Rollover date through the following setting: General Settings Window: Additional Days to Add to Rollover Date for Chart and Quote Board Rollovers (Global Settings >> General Settings >> Charts >> Charts) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
