Date/Time: Mon, 21 Apr 2025 13:14:36 +0000
Chartbook
View Count: 320
[2023-02-07 19:12:27] |
User585993 - Posts: 83 |
How can I resell my chartbook with custom indicators?
[2023-02-07 22:40:01] |
John - SC Support - Posts: 39362 |
How you do it is up to you. Note that we do not have tools to control the Chartbook itself, but we do for custom indicators. Refer to the following for how to protect custom indicators: Advanced Custom Study Interface and Language (ACSIL): Redistributing and Allowing Use Only by a Defined List of Users Also note the section below the above that gives you a way to send files to a specific list of customers. You do not have to use our distribution process, it is just there for your convenience. Also refer to the following items for how to limit other aspects of the custom study: ACSIL Programming Concepts: Limiting Study Access to Particular Chartbook and Symbol ACSIL Programming Concepts: Not Allowing Changes to Study Subgraph Settings For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
