Date/Time: Mon, 21 Apr 2025 13:05:47 +0000
Teton/Real account problems
View Count: 395
[2023-02-07 18:52:42]
User76183 - Posts: 69
Hello! I have problems with lagging data and I cannot also remove my orders:
Triggering next historical data download in queue. | 2023-02-07 10:47:35.362
No download requests in the queue to start downloads for. | 2023-02-07 10:47:35.362
Socket (4) | Socket gracefully closed by remote side. | 2023-02-07 10:47:35.552
Socket (4) | Closed. | 2023-02-07 10:47:35.552
Opened cached Intraday file: C:\SierraChart\SierraChart2480\Data\CLH23_FUT_CME.scid. Thread ID: 1444 | 2023-02-07 10:47:37.973
Opened cached Intraday file: C:\SierraChart\SierraChart2480\Data\GCJ23_FUT_CME.scid. Thread ID: 1444 | 2023-02-07 10:47:37.973
DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2023-02-07 10:47:57.090 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-02-07 10:47:57.090
DTC Client socket (1) | CloseSocket call. | 2023-02-07 10:47:57.091
DTC Client socket (1) | Max send buffers used during socket life: 4 | 2023-02-07 10:47:57.091
DTC Client socket (1) | Max send buffer size during socket life: 593 | 2023-02-07 10:47:57.091
DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-02-07 10:47:57.091
DTC Client socket (1) | Closed. | 2023-02-07 10:47:57.091
Connection to the external service has been lost. | 2023-02-07 10:47:57.092
Teton CME Order Routing | Waiting for socket receive thread to end | 2023-02-07 10:47:57.171
DTC Client socket (0) | CloseSocket call. | 2023-02-07 10:47:57.172
Teton CME Order Routing | Disconnected. | 2023-02-07 10:47:57.172
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-07 10:47:57.172
Teton CME Order Routing | Firm: Dorman | 2023-02-07 10:47:59.235
Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11091 | 2023-02-07 10:47:59.235
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-02-07 10:47:59.236
DTC Client socket (1) | New receive buffer size: 5242880 | 2023-02-07 10:47:59.236
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2023-02-07 10:47:59.236
Teton CME Order Routing | Network connection to server complete. | 2023-02-07 10:48:02.479
Teton CME Order Routing | Starting socket receive thread. | 2023-02-07 10:48:02.479
Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none | 2023-02-07 10:48:02.479
Teton CME Order Routing | Setting DTC encoding to Binary VLS | 2023-02-07 10:48:03.147
Teton CME Order Routing | Sending logon request message. | 2023-02-07 10:48:03.147
Teton CME Order Routing | Received logon response. | 2023-02-07 10:48:07.188
Teton CME Order Routing | Server Name: SC DTC Server. Build=44641. | 2023-02-07 10:48:07.188
Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 | 2023-02-07 10:48:07.188
Teton CME Order Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink.trading|SymbolSettings=cme_ilink_live.trading. | 2023-02-07 10:48:07.188
Teton CME Order Routing | Trading is supported. | 2023-02-07 10:48:07.188
Teton CME Order Routing | Order cancel and replace is supported. | 2023-02-07 10:48:07.188
Teton CME Order Routing | OCO Orders supported. | 2023-02-07 10:48:07.188
Teton CME Order Routing | Bracket Orders supported. | 2023-02-07 10:48:07.188
Teton CME Order Routing | Connected to server complete. | 2023-02-07 10:48:07.188
Triggering next historical data download in queue. | 2023-02-07 10:48:07.188
Teton CME Order Routing | Performing query for most recent Order Activity Date-Time. | 2023-02-07 10:48:07.258
No download requests in the queue to start downloads for. | 2023-02-07 10:48:07.258
Teton CME Order Routing | Requesting historical order activity from server. Start date-time UTC: 2023-02-07 15:03:49.033833 | 2023-02-07 10:48:07.261
Updated verified funded futures trading account ending date to: 2023-03-09 18:48:13 | 2023-02-07 10:48:13.840
Teton CME Order Routing | There has been no activity on the network socket for 47s. Will reconnect. | 2023-02-07 10:49:19.321
Connection to the external service has been lost. | 2023-02-07 10:49:19.321
Teton CME Order Routing | Waiting for socket receive thread to end | 2023-02-07 10:49:19.469
DTC Client socket (1) | CloseSocket call. | 2023-02-07 10:49:19.469
DTC Client socket (1) | Max send buffers used during socket life: 3 | 2023-02-07 10:49:19.469
DTC Client socket (1) | Max send buffer size during socket life: 329 | 2023-02-07 10:49:19.469
Teton CME Order Routing | Disconnected. | 2023-02-07 10:49:19.469
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-07 10:49:19.469
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-02-07 10:49:19.469
Teton CME Order Routing | Firm: Dorman | 2023-02-07 10:49:21.489
Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11091 | 2023-02-07 10:49:21.489
DTC Client socket (4) | Creating socket. Using TLS 1.2. | 2023-02-07 10:49:21.489
DTC Client socket (4) | New receive buffer size: 5242880 | 2023-02-07 10:49:21.489
DTC Client socket (4) | Connecting to IP: 208.185.224.129. | 2023-02-07 10:49:21.489
Teton CME Order Routing | Network connection to server complete. | 2023-02-07 10:49:21.728
Teton CME Order Routing | Starting socket receive thread. | 2023-02-07 10:49:21.728
Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none | 2023-02-07 10:49:21.729
[2023-02-07 20:53:13]
Sierra_Chart Engineering - Posts: 19285
How much of a lag do you notice? Refer to:
Prices / Data Falling Behind
Try canceling the orders following these instructions:
Trading Information Windows: Canceling Orders
Date Time Of Last Edit: 2023-02-07 20:53:24
