Date/Time: Mon, 21 Apr 2025 13:11:37 +0000
cant find other sierra versions to downgrade what happened
View Count: 335
[2023-02-07 15:42:58] |
GIANNIS TSIZIDIS - Posts: 1 |
[2023-02-07 17:36:21] |
John - SC Support - Posts: 39362 |
We are not understanding the issue. You can downgrade back to version 2204, although there may be a few specific versions that are not available (this would just be hit-or-miss if you happen across one). Refer to the following for the instructions to downgrade your software: Software Download: Full Control Rollback Procedure For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
