Date/Time: Mon, 21 Apr 2025 13:14:32 +0000
Unable to attach or detach this chart -- also missing EDIT CHART etc
View Count: 347
[2023-02-06 18:51:04] |
ss1776 - Posts: 19 |
<this thread is now private based upon the request of the User> How can I attach or detach this chart, also how can I see EDIT CHART Menus on it |
[2023-02-06 22:46:58] |
John - SC Support - Posts: 39362 |
Refer to the following for how to Attach and Detach charts from the main Sierra Chart window: Detaching and Attaching Chart Windows When a window is detached, it should have, by default, the Title Bar, Scrollbar, and Menu Bar. These can be turned off through the Chart menu. Refer to the information starting at the following: Chart Menu: Show Title Bar (Chart menu) If you have hidden these and you want to get one (or more) of them back, then you need to Right-Click in the Region Data Line and select "Show Menu" to select the options within the Menu. Note the section highlighted in Green in the documentation for "Show Menu". For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
