Date/Time: Mon, 15 Dec 2025 09:11:47 +0000
switchingfrom live trade accont to sim when i place order
View Count: 461
| [2023-02-06 15:25:13] |
| User764226 - Posts: 4 |
Hi i hav live trad accont , when i place order switch to sim trad |
| [2023-02-06 21:26:15] |
| John - SC Support - Posts: 43443 |
When this happens, it means that you do not have your Sierra Chart software connected to your live trading account. Who is your broker and what trading service do they have you setup to use (Rithmic, CQG, or Teton Order Routing)?
| [2023-02-07 19:35:38] |
Hi my trading service is CQG |
| [2023-02-07 19:37:25] |
my broker is AMP
| [2023-02-07 22:46:48] |
Then follow the instructions at the following link to connect your Sierra Chart to your CQG account: CQG Trading Platform Service: Setup Instructions Once that is done, then open your Chartbooks and select Edit >> Translate Symbols to Current Service. This will change the symbols in your charts to be the symbols needed by CQG. After that, you will be able to trade live, just be sure the option for Trade >> Trade Simulation Mode On does not have checkmark by it and you will be sending your orders to CQG. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
