Date/Time: Mon, 21 Apr 2025 13:11:43 +0000
VIX futures data for ES
View Count: 559
[2023-02-06 13:49:30] |
User250353 - Posts: 18 |
Hi I have service package 11, i just want to add the live data for VIx futures. can you please send me step by step guide to add this service. kind regards |
[2023-02-06 18:17:47] |
John - SC Support - Posts: 39362 |
Follow the Setup Instructions at the following link for the CFE: Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-02-06 18:57:26] |
What feed I need to pick John, am confused for the VIX. I have service package 11, do I need to deactivate or I need to update and renew. Kind regards |
[2023-02-06 23:02:07] |
You do not need to change your Service Package, as you are fine on Package 11. Start at the following link and go through the 2 sections (Sign the Agreements and Activate the Exchange): Denali Exchange Data Feed: Sign the Agreements (All Other Exchanges) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-02-07 06:57:14] |
Hi John What is the difference in cost from what am paying to having VIX added on? Kind regards |
[2023-02-07 15:53:34] |
The cost depends on whether you need Market Depth data or not. Here are the non-professional costs: - CFE Top of Book: $3.00 per month - CFE With Market Depth: $5.00 per month For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
