Date/Time: Mon, 21 Apr 2025 13:14:33 +0000
Number Bars: Highlighting Incomplete Auctions (Nonzero BidAsk Volume at High/Low)
View Count: 448
[2023-02-06 06:35:37] |
User688525 - Posts: 284 |
Hello Sierra, Instead of drawing a box around incomplete auctions ("Highlight Nonzero BidAsk Volume at High/Low"), is it possible to color the text instead? For example, in the attached, the "15x97" auction is incomplete. Can all of the text ("15x97"), or the "15" which has made it incomplete, be colored differently? Thank you |
[2023-02-06 18:02:02] |
John - SC Support - Posts: 39362 |
There is not a way to do this.
[2023-02-06 23:42:09] |
Hi John, Thank you for confirming. |
