Date/Time: Mon, 25 Nov 2024 11:32:57 +0000
Denali data feed with Interactive Brokers execution
View Count: 701
[2023-02-05 21:45:36] |
rkarrow - Posts: 9 |
Can I use the Denali data feed with Interactive Brokers TWS execution. In other words, using the Denali feed and my spreadsheet generates a signal, will that signal be executed by IB??? I wonder cuz the symbols used by Denali are not the same that IB uses. I trade the SP 500 mini contracts. Simply question I know Thanks, Robert Date Time Of Last Edit: 2023-02-06 02:51:32
[2023-02-06 16:23:53] |
Sierra_Chart Engineering - Posts: 17172 |
Yes this is fully supported. Wait for version 2480 for proper support for Interactive Brokers. There are some recent issues we are still working out with integration to TWS. Information about Denali: Denali Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-03-06 03:14:50] |
User309924 - Posts: 1 |
Has this been worked out? I am trying to connect Denali for data and IB for trading, however, I can only ever seem to have one or the other activated in Data/Trade Service Settings. I either have to select SC Data - All Services [data] which then uses Denali, but forces me into simulated trading/not connecting to Interactive Brokers, or if I select Interactive Brokers [trading] I don't think I am using Denali data. Really looking for help making these two work together. I am using version 2604 64-bit.
SC Screenshot.jpg / V - Attached On 2024-03-06 03:13:12 UTC - Size: 127.3 KB - 80 views |
[2024-03-06 17:21:53] |
Sierra Chart is specifically setup so you can get the data from us while trading with your selected trading service. As such, when you are connected to Interactive Brokers, you will get the data from us for the exchanges that you have active with us. Any other data would come from Interactive Brokers. Refer to the following: Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
