Date/Time: Sun, 13 Sep 2026 21:18:56 +0000
[Programming Help] - ACSIL Custom Study Button to Control Trading System
View Count: 2706
| [2023-02-04 15:23:20] |
| Tahir - Posts: 35 |
Hi, Is it possible to control existing study inputs with a Custom Study Button? I'm a beginner in Acsil and coding in general. I'm trying to build a custom study button that enables or disables the trading system based on alert condition. I have two systems one for buy and one for sell, so I want to have control over the system with a single click. I don't want to turn both of them off and I know yo can do that with menu item "auto trading enabled". thank you |
| [2023-02-04 17:45:34] |
| ondafringe - Posts: 337 |
Assuming I understand what you're trying to accomplish, IMO, you should put both systems -- buy and sell -- in one study. Then you can configure two keyboard shortcuts, one to turn the buy on/off and the other to turn the sell on/off. That's a manual way of doing it, but you also said you wanted it based on an alert condition (?), which can be automated and accomplished with your code.
| [2023-02-04 17:54:55] |
| Tahir - Posts: 35 |
I think I did a bad job of explaining what I need. In my chart I have a "Trading System Based On Alert Condition" study. I want to add a button that controls it's "Enable/Disable" input. Is there a way to do that without actually having to write the study? |
| [2023-02-04 18:47:01] |
Take a look at this: ACSIL Interface Members - Functions: sc.SetChartStudyInputInt() |
| [2023-02-04 19:50:49] |
| Tahir - Posts: 35 |
Thank you that worked!
| [2023-02-19 03:40:31] |
| Ticks - Posts: 212 |
Could you post the code to how you got this to work?
