Date/Time: Thu, 28 Nov 2024 01:36:54 +0000
Footprint chart - right side of screen not showing data
View Count: 603
[2023-02-04 12:50:04]
User300096 - Posts: 8
Hi -- hopefully this is an easy settings or scale fix. Got this footprint chart template, however a large portion of the right side of the screen does not show any data. When I zoom in on certain prints this gets even worse, only showing one print at a time.
I remember having a similar issue with time charts but cannot figure out a fix. Thanks!
https://www.sierrachart.com/image.php?Image=167551484993.png
https://www.sierrachart.com/image.php?Image=167551489429.png
[2023-02-06 16:52:20]
John - SC Support - Posts: 36350
It looks like that chart as the option for Lock Fill Space enabled. Refer to the following:
Chart Menu: Lock Fill Space (Chart menu)
[2023-06-11 12:38:52]
VLiviu - Posts: 223
HI all
I wont open anew post on a similar matter.
I wanna keep this space (see attached) at a constant distance between last candle and the right margin.
I activated lock fill space but somehow the last candle gets drawn over the volume
Please advice
Thank you
imageScreenshot 2023-06-11 083414.png / V - Attached On 2023-06-11 12:38:38 UTC - Size: 135.08 KB - 194 views
[2023-06-11 14:02:57]
Sierra_Chart Engineering - Posts: 17199
We do not see what you are referring to:
[2023-06-11 14:16:10]
VLiviu - Posts: 223
Right, because i've moved the last candle ofer left to draw that red arrow :)
I'll take another one when happens
[2023-06-12 13:14:16]
Disable the option for "Lock Fill Space" and then set your last bar where you want it to be, and then enable "Lock Fill Space".
Note that when you change Bar Spacing, the amount of Fill Space that is locked will change, as it is based on the number of bars.
[2023-06-12 13:44:50]
VLiviu - Posts: 223
yep, already figured it out.
thank you sir
