Date/Time: Tue, 18 Feb 2025 21:56:27 +0000
#41 Using the spreadsheet study - for the formula to automatically down the column
View Count: 290
[2023-02-04 01:39:55]
User886162 - Posts: 1
Trying to use the Spreadsheet System/Alert
The Spreadsheet is correctly populated with Data
But the formula does not automatically fill down the formula column???
Per #41 Using the spreadsheet study - "for the formula to automatically down the column
Global settings>>Spreadsheet setting>> Spreadsheet Study>> Recalc the chart Formula.. is set to "YES"
Help??
[2023-02-04 02:29:02]
user_xyz - Posts: 445
See here this should help...
Spreadsheet auto populate formula isn't working
