Date/Time: Mon, 21 Apr 2025 04:41:23 +0000
NQ Futures number bars displaying very incorrectly.
View Count: 445
[2023-02-03 19:26:57]
jakubfxpl - Posts: 1
Hello, I'm having an issue with my NQ Futures chart displaying number bars very weirdly, here's a screenshot. It's very cluttered and impossible to read.
https://ibb.co/Jpc6ThM
Date Time Of Last Edit: 2023-02-03 21:43:17
[2023-02-03 21:55:47]
John - SC Support - Posts: 39362
There is nothing particularly wrong with that display. You have a single number displayed and is set to be right-aligned, and the Background Type is set to Full Background. And then there is a lot of information displayed per bar, especially since these are 5 minute bars (it just means more range per bar).
Refer to the information at the following link and the section after it (especially the section on adjusting the tick size - although we recommend using the Volume at Price Multiplier mentioned):
Numbers Bars: Scaling a Numbers Bars Chart
