Date/Time: Tue, 26 Nov 2024 19:38:15 +0000
Applying a chart's format to another one
View Count: 1159
[2014-06-09 06:30:41] |
Dom7364 - Posts: 257 |
Is there a way to apply a chart or chartbook's format to another chart or another whole chartbook (i.e, to all chart wthin a chartbook?) Many thanks |
[2014-06-10 04:56:56] |
Possible?
[2014-06-10 05:23:00] |
The closest Sierra Chart has is the ability to duplicate a chart. This is documented here: https://www.sierrachart.com/index.php?l=doc/helpdetails20.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-06-10 05:45:37] |
Thank you. Using the chart duplication, yes, thanks. I was just looking to copy the format over to another chart (so fonts, text siez, colours, backgroud, in short anything just format related). Would be a nice addition in terms of saving time, or applying a format you spent time on setting up onto another/new chart. |
