Date/Time: Mon, 21 Apr 2025 04:41:24 +0000
trading no efectua orden
View Count: 452
[2023-02-03 16:48:32]
luciana - Posts: 24
Hola
Cuando efectuo una orden, me devuelve de inmediato al modo simulacion.
Descarto el boton modo simulacion, y cuando se genera una transaccion vuelve a estar seleccionado el modo simulacion
de forma automatica.
En la ventana de mensajes me aparece la siguiente informacion:
MESH23-CME[M] #4 | Entrada de pedido de usuario | Incapaz de aplanar/retroceder. La posición no existe. Las órdenes que no sean de mercado que funcionen se cancelarán | Símbolo: [Sim]MESH23-CME | TradeAccount: Sim1 | 2023-02-03 09:58:10.817 *
Actualmente tengo una cuenta activa con AMP FUTURE.
Gracias
[2023-02-03 18:43:41]
John - SC Support - Posts: 39362
From Google Translate:
Hello
When I make a command, it immediately returns me to simulation mode.
I discard the simulation mode button, and when a transaction is generated, the simulation mode is selected again
automatically.
The following information appears in the message window:
MESH23-CME[M] #4 | User Order Entry | Unable to flatten/retreat. The position does not exist. Non-market orders that work will be canceled | Symbol: [Sim]MESH23-CME | TradeAccount: Sim1 | 2023-02-03 09:58:10.817 *
I currently have an active account with AMP FUTURE.
Thank you
Your Sierra Chart is not connected to your live trading account. This is why it keeps changing back to "Simulation" mode.
Since you are setup with AMP, they will most likely have set you up with CQG for your order routing. If this is correct, then follow the instructions at the following link to connect your Sierra Chart to your CQG account:
CQG Trading Platform Service: Setup Instructions
