Date/Time: Mon, 21 Apr 2025 04:50:13 +0000
CROSSFROMBELOW sometimes not detected
View Count: 390
[2023-02-03 14:17:49] |
User286186 - Posts: 22 |
Hello, I created a custom study based on Color Bar Based on Alert Condition. My study detects a CROSSFROMBELOW between two lines. The problem is that the same crossing is sometimes detected and sometimes not. I also tried a CROSSFROMABOVE the other way around, but still I have the same result. As you can see in the screenshot below, I coded that if the green line crosses the orange line from below, a signal is displayed. This is true the firs and the second time (marked with pink circles) but not the third time (marked with yellow circle). Could you please tell me why ? Thank you very much. |
[2023-02-03 15:01:02] |
Sierra_Chart Engineering - Posts: 19285 |
You really have to examine the values closely at the point of crossover and see what the issue is. We cannot tell from our perspective. You can always write your own crossover formula. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-02-03 15:35:57] |
Sawtooth - Posts: 4209 |
This might help you troubleshoot: Study/Chart Alerts And Scanning: The Effect of the Value Format on Identifier Values |
