Date/Time: Mon, 21 Apr 2025 04:44:14 +0000
different values
View Count: 384
[2023-02-03 11:26:50]
Yeager - Posts: 132
Myself and 3 other traders have the same DTS service settings. We also run the recent 2479 SC version.
When using ECI Vwap study v1.5, settings set to Year and extending IN:5. We get different values.
We chart CLH23_FUT_CME
Mine are 75.31- theirs are 76.24.
All chart settings and DTS settings are identical.
I then ran this test on my laptop and with thhe same DTS settings as my main system and the eci level comes in line with my friends.
Please help as I think my data is corrupt on my main system.
This is Teton order routing through Phillips Capital.
Many thanks
[2023-02-03 11:33:11]
Yeager - Posts: 132
I would normally look at the ECI vwap for a fix here, however I just ran a Delete all data and download and now the levels on the candle sticks have adjusted massively and the NEW eci VWAP level is 77.56. Added to this, there are 2 new users that have different levels with the same DTS settings and teton.
As you can appreciate, Im really struggling to now.hold trust in any of these levels and consistency of the data I am getting not only on oil but on all data.
This is a major issue.
Date Time Of Last Edit: 2023-02-03 11:43:30
[2023-02-03 15:06:23]
wwwingman - Posts: 185
Hi.
I am the developper of ECIVwap.
As far as I can understand, your description suggests data corruption or difference in the data provider settings.
Be sure all sierra instances have the same data provider, same data provider settings, especially the Intraday Data storage time unit, but not only.
--W.
Date Time Of Last Edit: 2023-02-03 17:21:28
