Date/Time: Tue, 26 Nov 2024 18:17:58 +0000
DOM for markets without market depth
View Count: 1129
[2014-06-09 02:42:45]
User25540 - Posts: 22
An Interactive Brokers client who doesn't subscribe market data (ex. Nikkei 225 mini in OSE) will get a DOM like the attached png graph.
How to adjust the DOM price to near 15200 so that I can send a blind order by directly click the price? It's more convenient than select limit order and type the price manually.
Thank you.
imagen225.png / V - Attached On 2014-06-09 02:37:45 UTC - Size: 71.38 KB - 383 views
[2014-06-09 04:15:07]
We understand what you mean.
The only thing you can do is compress the scale of the DOM and then move the prices down in order to bring the price 15200 into view. Refer to this page for instructions:
http://www.sierrachart.com/index.php?l=doc/doc_ScalingTheChartDOM.html
[2014-06-09 05:17:43]
Thank you for giving direction that I can try.
I right-click on the scale of numbers and select "scale settings"-> "user defined" then fill top, bottom of range with 15200 and 15100 respectively. It can work and meet my needs.
[2014-06-09 05:29:50]
We have not tested this, but it sounds like this should work. Therefore it will be a good solution.
