Date/Time: Mon, 21 Apr 2025 04:50:12 +0000
question about ninja trader.
View Count: 815
[2023-02-03 00:05:11] |
JxmBlow - Posts: 1 |
So I am doing an evaluation account for ninja trader is there a way where i could just buy sierra data and get real time data right away even before being able to link the ninja trader account?
[2023-02-03 01:30:53] |
Sierra_Chart Engineering - Posts: 19285 |
What markets do you need data for or want to trade? For example, what particular futures, Forex or stock symbols. You can also give us the exchanges that the particular symbol or symbols trade on. If you require real-time futures data, then refer to: https://www.sierrachart.com/index.php?page=doc/doc_FuturesData.php Be sure to read the page linked above completely before making a further inquiry regarding real-time *futures* data. You also are not going to be able to link your ninja trader account. That is not supported. Refer to: Using Sierra Chart with Ninja Trader Brokerage Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-02-03 01:31:22
