Date/Time: Mon, 21 Apr 2025 04:38:28 +0000
Connection error from service
View Count: 365
[2023-02-02 19:29:38]
User764226 - Posts: 4
Hi
i hav no connection from 2 days ago , and i got service connection error message "connection error from service: CQG logon unsuccessful.your logon is disable "
hope you fix it as soon as possible
thanks
[2023-02-02 23:01:53]
John - SC Support - Posts: 39362
Your broker has disabled your CQG account. You need to ask your broker about this. We have no control over this, we just report the error.
[2023-02-03 01:16:17]
Sierra_Chart Engineering - Posts: 19285
To access historical and streaming market data independent from your Trading service. Follow these instructions.
Set "Global Settings >> Data/Trade Service Settings >> Current Selected Service" to "SC Data-All Services".
Press "OK"
And then translate the symbols in your Chartbooks and Sierra Chart using this "Edit' menu command:
Edit Menu: Edit >> Translate Symbols To Current Service (Translate Symbols to Current Service)
You can then use the data provided by Sierra Chart independent of your trading service.
