Date/Time: Mon, 21 Apr 2025 04:38:28 +0000
Window width not saved
View Count: 330
[2023-02-02 19:12:30] |
BenjFlame - Posts: 337 |
Hi, I have some windows from which I removed all scrollbars, axis, title, menu... I just use it as a type of meter: tall and very thin. Each time I restart sierra chart, the window width is not remembered as if there is a minimum width imposed. Can't this be prevented? So window width is exactly as it is on last save? It does this only on very thin windows. |
[2023-02-03 14:35:20] |
Sierra_Chart Engineering - Posts: 19285 |
The size and position of every window used within Sierra Chart is saved and restored using operating system functions . If this is not working correctly, then this is an operating system issue.
