Date/Time: Sat, 26 Sep 2026 13:46:05 +0000
[Programming Help] - Help with ACSIL
View Count: 1667
[2023-02-02 18:34:23]
User538264 - Posts: 26
Hello, I have written this code for one of my studies. The code is working fine after one cycle of crossovers(See the code) is completed and it gives me correct levels. But when I initially apply this to the chart, the values are wrong and only one level is being plotted.
What am I missing here?
int barsSinceCross(SCConstFloatArrayRef arr, int occurence) {
  int bars = 1;
  int reps = 1;
  for (int i = arr.GetArraySize() - 1; i > 0; i--)
    if (arr[i] == 0.0)
      bars++;
    else if (reps < occurence)
      reps++;
      bars++;
    else
      break;
  return bars;
SCSFExport scsf_AZA_MACDCrossoverLevels(SCStudyInterfaceRef sc)
  /*  SCSubgraphRef Buy = sc.Subgraph[0];
    SCSubgraphRef Sell = sc.Subgraph[1];
    SCSubgraphRef MACDData = sc.Subgraph[2];
  SCSubgraphRef Subgraph_MACDLine = sc.Subgraph[0];
  SCSubgraphRef Subgraph_SignalLine = sc.Subgraph[1];
  SCSubgraphRef Subgraph_MACDData = sc.Subgraph[2];
  SCSubgraphRef Subgraph_Histogram = sc.Subgraph[3];
  SCSubgraphRef Subgraph_MACDCross = sc.Subgraph[4];
  SCFloatArrayRef Array_CrossUp = sc.Subgraph[4].Arrays[4];
  SCFloatArrayRef Array_CrossDn = sc.Subgraph[4].Arrays[5];
  SCInputRef Input_InputData = sc.Input[0];
  SCInputRef Input_FastLen = sc.Input[1];
  SCInputRef Input_SlowLen = sc.Input[2];
  SCInputRef Input_MACDLen = sc.Input[3];
  SCInputRef Input_MAType = sc.Input[4];
  if (sc.SetDefaults)
    // Set the configuration and defaults
    sc.GraphName = "AZA MACD Levels Script";
    sc.GraphRegion = 1;
    sc.AutoLoop = 1;
        Buy.Name = "Buy";
        Buy.PrimaryColor = RGB(0, 255, 0);  // green
        Buy.DrawStyle = DRAWSTYLE_ARROWUP;
        Buy.LineWidth = 2;  //Width of arrow
        Buy.DrawZeros = 0;
        Sell.Name = "Sell";
        Sell.DrawStyle = DRAWSTYLE_ARROWDOWN;
        Sell.PrimaryColor = RGB(255, 0, 0);  // red
        Sell.LineWidth = 2; //Width of arrow
        Sell.DrawZeros = 0;
    Subgraph_MACDCross.Name = "Cross";
    Subgraph_MACDCross.PrimaryColor = RGB(0, 255, 0);
    Subgraph_MACDCross.DrawStyle = DRAWSTYLE_ARROWDOWN;
    Subgraph_MACDCross.LineWidth = 1;
    Subgraph_SignalLine.Name = "Signal Line";
    Subgraph_SignalLine.PrimaryColor = RGB(0, 255, 0);
    Subgraph_SignalLine.DrawStyle = DRAWSTYLE_LINE;
    Subgraph_SignalLine.LineWidth = 1;
    Subgraph_MACDLine.Name = "MACD Line";
    Subgraph_MACDLine.PrimaryColor = RGB(250, 0, 0);
    Subgraph_MACDLine.DrawStyle = DRAWSTYLE_LINE;
    Subgraph_MACDLine.LineWidth = 1;
    Subgraph_Histogram.Name = "Histogram";
    Subgraph_Histogram.PrimaryColor = RGB(255, 255, 0);
    Subgraph_Histogram.DrawStyle = DRAWSTYLE_BAR;
    Subgraph_Histogram.LineWidth = 2;
    Subgraph_Histogram.AutoColoring = AUTOCOLOR_POSNEG;
    Input_InputData.Name = "Input Data";
    Input_InputData.SetInputDataIndex(SC_LAST);
    Input_FastLen.Name = "Fast Moving Average Length";
    Input_FastLen.SetInt(12);
    Input_FastLen.SetIntLimits(1, MAX_STUDY_LENGTH);
    Input_SlowLen.Name = "Slow Moving Average Length";
    Input_SlowLen.SetInt(26);
    Input_SlowLen.SetIntLimits(1, MAX_STUDY_LENGTH);
    Input_MACDLen.Name = "MACD Moving Average Length";
    Input_MACDLen.SetInt(9);
    Input_MACDLen.SetIntLimits(1, MAX_STUDY_LENGTH);
    Input_MAType.Name = "Moving Average Type";
    Input_MAType.SetMovAvgType(MOVAVGTYPE_EXPONENTIAL);
    return;
  if (sc.IsFullRecalculation && sc.Index == 0)
    sc.ClearAllPersistentData();
  // Do data processing
  sc.MACD(sc.BaseDataIn[Input_InputData.GetInputDataIndex()], Subgraph_MACDData, sc.Index, Input_FastLen.GetInt(), Input_SlowLen.GetInt(), Input_MACDLen.GetInt(), Input_MAType.GetInt());
  Subgraph_MACDLine[sc.Index] = Subgraph_MACDData.Data[sc.Index];
  Subgraph_SignalLine[sc.Index] = Subgraph_MACDData.Arrays[2][sc.Index];
  Subgraph_Histogram[sc.Index] = Subgraph_MACDLine[sc.Index] - Subgraph_SignalLine[sc.Index];
  int barsSinceCrossUp = 0;
  int barsSinceCrossDn = 0;
  float swingHigh;
  float swingLow;
  float &highLevel = sc.GetPersistentFloat(0);
  float &lowLevel = sc.GetPersistentFloat(1);
  int swingHighIndex;
  int swingLowIndex;
  int &highIndex = sc.GetPersistentInt(2);
  int &lowIndex = sc.GetPersistentInt(3);
  if (sc.GetBarHasClosedStatus() == BHCS_BAR_HAS_CLOSED)
    if (sc.CrossOver(Subgraph_SignalLine, Subgraph_MACDLine) == CROSS_FROM_BOTTOM)
      Array_CrossDn[sc.Index] = 1;
      swingHigh = sc.GetHighest(sc.High, sc.Index - barsSinceCross(Array_CrossDn, 1)+1, barsSinceCross(Array_CrossUp, 1) - barsSinceCross(Array_CrossDn, 1));
      swingHighIndex = sc.GetIndexOfHighestValue(sc.High, sc.Index - barsSinceCross(Array_CrossDn, 1) + 1, barsSinceCross(Array_CrossUp, 1) - barsSinceCross(Array_CrossDn, 1));
      sc.SetPersistentFloat(0, swingHigh);
      sc.SetPersistentInt(2, swingHighIndex);
    else if (sc.CrossOver(Subgraph_SignalLine, Subgraph_MACDLine) == CROSS_FROM_TOP)
      Array_CrossUp[sc.Index] = 1;
      swingLow = sc.GetLowest(sc.Low, sc.Index - barsSinceCross(Array_CrossUp, 1)+1, barsSinceCross(Array_CrossDn, 1) - barsSinceCross(Array_CrossUp, 1));
      swingLowIndex = sc.GetIndexOfLowestValue(sc.Low, sc.Index - barsSinceCross(Array_CrossUp, 1) + 1, barsSinceCross(Array_CrossDn, 1) - barsSinceCross(Array_CrossUp, 1));
      sc.SetPersistentFloat(1, swingLow);
      sc.SetPersistentInt(3, swingLowIndex);
    else
      Array_CrossDn[sc.Index] = 0;
      Array_CrossUp[sc.Index] = 0;
    SCString logText;
    logText.Format("lowindex = %d \n low = %f \n highindex = %d \n high = %f", lowIndex, lowLevel, highIndex, highLevel);
    sc.AddMessageToLog(logText, 0);
    s_UseTool Tool1;
    int &r_LineNumber = sc.GetPersistentInt(4);
    //sc.SetPersistentInt(4, 1);
    if (r_LineNumber != 0)
      Tool1.LineNumber = r_LineNumber;
    Tool1.LineNumber = 1;
    Tool1.ChartNumber = sc.ChartNumber;
    Tool1.Region = 0;
    Tool1.DrawingType = DRAWING_HORIZONTAL_RAY;
    Tool1.DisplayHorizontalLineValue = 1;
    Tool1.BeginValue = highLevel;
    Tool1.BeginDateTime = sc.BaseDateTimeIn[highIndex];
    Tool1.Color = RGB(255, 0, 0);
    Tool1.LineWidth = 2;
    Tool1.AddMethod = UTAM_ADD_OR_ADJUST;
    sc.UseTool(Tool1);
    r_LineNumber = Tool1.LineNumber;
    s_UseTool Tool2;
    int &s_LineNumber = sc.GetPersistentInt(5);
    //sc.SetPersistentInt(5, 2);
    if (s_LineNumber != 0)
      Tool2.LineNumber = s_LineNumber;
    Tool2.LineNumber = 2;
    Tool2.BeginValue = lowLevel;
    Tool2.BeginDateTime = sc.BaseDateTimeIn[lowIndex];
    Tool2.Color = RGB(0, 255, 0);
    Tool2.ChartNumber = sc.ChartNumber;
    Tool2.Region = 0;
    Tool2.DrawingType = DRAWING_HORIZONTAL_RAY;
    Tool2.DisplayHorizontalLineValue = 1;
    Tool2.LineWidth = 2;
    Tool2.AddMethod = UTAM_ADD_OR_ADJUST;
    sc.UseTool(Tool2);
    s_LineNumber = Tool2.LineNumber;
  else
    return;
Thanks in advance.
