Date/Time: Mon, 21 Apr 2025 13:05:49 +0000
last in first out not working
View Count: 475
[2023-02-02 16:42:59]
william bolger - Posts: 29
Screen shot attached.
Why is the last in first out not working properly?
image1111.PNG / V - Attached On 2023-02-02 16:42:13 UTC - Size: 35.04 KB - 129 views
[2023-02-04 00:46:52]
Sierra_Chart Engineering - Posts: 19285
It should be clear that there is insufficient information provided. The matching of order fills definitely works properly. Refer to the information here:
Trading Information Windows: How Average Price for Positions Is Calculated and Used
And also here:
Chart Trading and the Chart DOM: Accurate Entry/Exit State, Fill Matching and Position Quantities
Date Time Of Last Edit: 2023-02-04 00:47:47
[2023-02-06 19:04:21]
This is not what I asked.
I have selected. Last in first out.
But as you can clearly see. It is going with first in first out.
I shared my settings and asked why is it not doing as selected.
[2023-02-07 00:10:01]
How are we able to see this? We do not know what you are referring to.
