Date/Time: Tue, 26 Nov 2024 18:45:50 +0000
Price Scale
View Count: 984
[2014-06-08 02:43:00] |
User72407 - Posts: 31 |
The price scale on the 15 min chart is locked. The candles are squashed verically and I can not expand them to make them readable. I can move the chart up or down by dragging the price scale, but it has no effect on the scale itself. Reset Scale has no effect. I have the chart scale selected as automatic, with the bottom two boxes of the constant range scale ticked, just like the other time scale charts. The others work fine, but not the 15 minute chart. http://www.sierrachart.com/image.php?l=1402194826205.png What to do? Thanks |
[2014-06-08 03:08:46] |
Refer to the documentation here: http://www.sierrachart.com/index.php?l=doc/doc_Scaling.html#BasingScalePriceBars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
