Date/Time: Mon, 21 Apr 2025 04:38:27 +0000
Is it Possible to have Two Time and Sales Windows up at the Same Time?
View Count: 584
[2023-02-02 14:35:59] |
localman - Posts: 40 |
I am trying to have two Time and Sales windows with different values up at the same time but it seems that I can only have one running per chart. I currently have a couple of charts in the main trading window and then several charts that are detached from my main trading window on different monitors. It seems that I can only have one T&S window up for the main trading window despite multiple charts and then I have to add an additional T&S window from one of my detached charts. That in and of itself is fine but when I click on one of my charts in the main window the second T&S window disappears until I click on it's parent chart. I've seen the attach/detach feature within the T&S menu but that doesn't seem to help and has actually disappeared one T&S window completely. Any help is appreciated. |
[2023-02-02 17:48:25] |
John - SC Support - Posts: 39362 |
You can not do what you are wanting to do. You can only have 1 Time and Sales window open per symbol per Chartbook. And when you have another Chartbook open the Time and Sales Windows will not be visible when you have a chart from the other chartbook active. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-02-02 20:22:47] |
Ok, that's unfortunate. Thanks John.
[2023-02-03 13:56:57] |
For posterity, what I was hoping to do is simply have multiple T&S windows up at the same time regardless of position. The way to do this was to simply move the T&S windows off of my main chartbook window or shrink that window and then place the T&S windows in that newly formed space. Then I detached them and then I clicked always on top and voila, all visible. |
