Date/Time: Mon, 21 Apr 2025 04:35:53 +0000
Chart Settings
View Count: 380
[2023-02-02 13:51:13] |
TravelGoals - Posts: 14 |
Good morning, I clicked something wrong accidentally yesterday. I want to only be in ESH23 but somehow the symbol row where it has always said it is now grayed out and not letting me put it back there. Happened when I was toggling back from micro ES for the action and I clicked the wrong box. Anyways, I think this is wrong and I want it to be correct so I do not have any execution errors. Help please! Thanks! https://www.sierrachart.com/image.php?Image=1675345683662.png |
[2023-02-02 17:27:06] |
John - SC Support - Posts: 39362 |
We do not see the Symbol entry as being "grayed out" and it never can be. You can change the symbol in the line for Symbol on the Chart Settings. Refer to the following for how to use that particular field type on that window: Settings Windows Interface: Value Field (Working with Sierra Chart Windows >> Selection Specific Options) There is no reason to have the same symbol listed for the Trade and Current Quote Symbol, so you should remove that entry. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-02-02 17:53:44] |
Sierra_Chart Engineering - Posts: 19285 |
Left click twice on where the Symbol is to change it.
[2023-02-02 21:43:05] |
Please see the image I added to the issue. It will not accept any clicks in that row. It is grayed out and does not respond to any clicking or double clicking.
[2023-02-02 23:53:38] |
The line that states "Symbol (Action)" is the line you need to click. It is not grayed out. Click towards the right where the symbol is currently listed and it states "ESH3.CME".
