Date/Time: Mon, 21 Apr 2025 04:44:12 +0000
Incremental Weekly High/Low's
View Count: 351
[2023-02-02 08:11:53] |
StephenL - Posts: 120 |
Hi guys, I use 'High/Low for Time Period' for daily high/low's and set it to display incrementally which is a great help. I then use 'Period OHLC-Variable Period' for weekly high/low's but there is no option to display incrementally. Any suggestions to get weekly period high/low's to display incremental? Thanks |
[2023-02-02 16:29:48] |
John - SC Support - Posts: 39362 |
You would have to modify the Period OHLC - Variable Period study to do this. It is available in the Studies5.cpp file in the ACS_Source folder under your main Sierra Chart installation folder. Refer to the following: How to Build an Advanced Custom Study from Source Code For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
