Date/Time: Mon, 21 Apr 2025 04:44:14 +0000
Trade window
View Count: 434
[2023-02-01 20:58:20] |
wayne popham - Posts: 3 |
Can I get the trade window to work? I'm using delayed data on Trading Evaluator.
[2023-02-01 23:18:09] |
John - SC Support - Posts: 39362 |
The Trade Window should work just fine with the Trading Evaluator. If you are using Delayed Streaming Data, then make sure you are connecting to the Trading Evaluator - Delayed. If you are still having an issue, then tell us what exactly is occurring. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-02-02 00:46:44] |
I get the message. "Trading Evaluator-Delayed(order rejected)Info:Trade account"unset is not authorized. Authorized accounts:. Internal Order ID: 197. Service Order ID: (none)Symbol YMH23. 2023-02-01 19:36.56.903*"
[2023-02-02 02:00:01] |
[2023-02-02 16:22:00] |
If you have setup an account for the Trading Evaluator - then it sounds like it is not selected in the Trade Window. Be sure that your Trade Window for each chart from which you want to place orders, has the proper Account selected. Refer to the following for how to do this: Basic Trading and the Trade Window: Main/C >> Trade Account (Selecting Trade Account for Chart / Trade DOM) Otherwise, it sounds like you may not have setup an account on the Trading Evaluator. Refer to the instructions here: Simulated Futures Trading Service: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
